Batterie Voltage Control LPC2300
Hello, I'm using an LPC2368. The RTC is supplied by a battery. Is there a possability to check the battery voltage to generate an error for the customer? I don't want measure by AD Converter. Do you have a solution how can I do this with software?
thanks
