Using STM32F103ZE and IAR Embedded Workbench IDE 5.4 using assembler (no C).
The program assembles and links with no errors. When selecting "download and debug" option the following errors occur:
Warning: __vector_table symbol not found. E-entry value: 0x08000000 does not match reset vector value: 0x5c24f64e Initial SP-main value: 0xba00f8df uncertain. Warning - stack pointer is set up to incorrect alignment. Stack address: 0xba00f8df
I am using the standard "generic_cortex.icf" which contains: "define symbol __ICFEDIT_intvec_start__ = 0x00000000" which I have tried changing to "define...=0x20000000" but this does not fix the error.
Program contains at the top: SECTION CSTACK:DATA:NOROOT(3) SECTION .intvec:CODE_NOROOT(2) PUBLIC __vector_table PUBLIC __iar_program_start PUBLIC __vector_table_0x1c DATA __vector_table DCD sfe(CSTACK) DCD __iar_program_start DCD NMI_handler etc.
I would greatly appreciate assistance with this. I have combed through all the reference manuals and trawled the internet to no avail. Thank you
Would you complain to Ferrari when your Ford develops a fault?
Oh, thanks for your very excellent help.
Well, don't you think that the IAR forum might be a better place for asking a question relating to something your seeing when using IAR tools?
Hmmm?
@Reluctant Consultant,
Common man, once in a zillion years we have a woman (?) coming down here to get some help and you send her away...
The first 2 words of a .hex image contains the entry point to the program and the initial stack pointer. It smells like some setting in the IDE that causes inappropriate code to be generated for your target.
Thanks, Michael, for your reply. I will examine your suggestion.
