If function has to be shared in two files. (or same question for varaibles also) So what to do is declare it as extern in other file.
Now in two files this function has been used. Now will it make any difference in code performance/size if I declare it in all files (20 other .c files) using extern keyword.
As according to this c-faq.com/.../decldef.html.
I am thinking to place all function declaration in one file global.h & use it.
But my other files don't need that function. Using global.h made that function visible in those files also.
Now is there any code size/performance issues.
no. there is no EXECUTABLE code size or performance issue. but,,,,,, it is not good practice to make everything seeable to everything.
Then how to ensure that there is defination & declaration remain consisten. If in code, at one time the defination is changed then it has to searched in all file s7 declaration has to be changed accordingly. is there any method by which it can be done more easily
put the declarations in to a header file. you must edit the file.
If all C files that references a specific function - or that contains the actual implementation of the function - always include the header file that has the prototype, then the compiler will make sure that your code is consistent. I.e. that the information in the header file matches how you implemented the function and how you are using the function.
