I want to port an opensource project using winavr to keil mdk, but keil throw warning: #1271-D: variable-length array field type will be treated as zero-length array field type And when I debug in program, some variable array mixed with some other variable in address, this cause the program fail. So how to port project that use variable array ?
Chris
So does keil support true vla support or it is just a 0 length array? Why here the defined vla mixed with other variable defined in the same function? As I know, the vla area is located in the stack, but i think keil should trace the length of array and should not be mixed with other varible defined in this function, am i right? If it is just a 0 length array, I think I should just use vla as the last defined variable in this function.
Use the vla as Not the last, but the only variable in this function
Might be worth searching here: infocenter.arm.com/.../index.html
