I have done ,whatever mention in following link
but not able to make good documentation
http://www.keil.com/support/docs/2734.htm
please suggest me how to use doxygen properly with keil
Advance thanks
You totally forgot to ask what you want information about.
The link tells how to make use of Doxygen from within the IDE.
http://www.doxygen.org contains all information about what you can do with Doxygen.
So where are you stuck?
Your source code needs to be commented using a specific format that doxygen understands. The doxygen user's manual explains how to do that.
'Doxygen' has nothing to do with uVision ! IT is a (independent) (auto/self) documentation generation tool. It basically uses the information provided in the source code( in form of comments which follow doxygen protocol) to build a documentation. This is the wrong place for learning Doxygen usage ! If you would take some time and look at the official site of doxygen(http://www.doxygen.org), you would understand it better. The Doxygen site provides comprehensive usage examples and how to's ! Good luck !
