Hello I have written a ADC code for Lpc2138 but the thing i i dont know how to check the digital data. can anyboby please help me to solve the problem which i am facing ?
Thank
"check" it for what, exactly?!
"can anyboby please help me to solve the problem which i am facing?"
Before that is possible, I think you'll need to be much clearer about what problem, exactly, you are facing!
You should also explain what you've tried, what results you got, why those results are not what you wanted, and what you've done to try to resolve the issue...
I wanted to see the converted digital data. I tried using pheripherals ->adc 0 . ..there I have changed the analoug input .but if I go through the ADDREGISTER(data register) the expected data was not there. And also I wanted to know how to access that data from that data register, for further process say for example display that using lcd .
In your opening post you said, "I have written a ADC code for Lpc2138"
How can that be possible if you can't even access peripherl registers?!
Have you looked at any of the examples on this site, the NXP site or, in fact, anywhere??
Referred a code and written according to my need. what you are saying is correct even i don't know how to access the peripheral register, If you don't mind you can tell me how to access those registers .
Well if you don't know that, you did not _write_ anything, OK? So, did you look at available sample code or do you need to be spoon-fed?
Before looking at sample code (which will, almost certainly, be in 'C'), do you actually know the 'C' programming language?
Dont you people feel shame to be like this if you know the solution post are else do your business.. thanks for your support.. i found the solution on my own . i hope u doesn't know any thing about that and wasting your time in posting such a nonsense thread.
Shame for what - getting you to do your own work?
