Hi I'm trying to interface with SD/micro SD cards using my LPC236 I have used the sample code in Boards/Keil/MCB2300/RL/FlashFS/SD_File and change the main function to this:
int main (void) { char *sp,*cp,*next; FILE *file; U32 i; SCS |=0x00000001; FIO2DIR =(1<<10); //p2.10 is a test LED FIO2SET = (1<<10); delay_ms(2500); FIO2CLR=(1<<10); delay_ms(2500); init_card(); FIO2SET=(1<<10); file=fopen ("Testjavad.txt","w"); fputs("This is an example for fputs.\n", file); while (1) { } }
This picture shows how I have connected my pins: upcity.ir/.../76769829806565195328.jpg
When the 4GB micro SDHC memory is in, the power consumption of my board is increased by 100mA, but no change is made to the card When a 256MB SD card is in, the power consumption of my board is increased by 300mA , but no change is made to the card Also the program is stopped at init_card(); because I see the LED is OFF
Could anyone help or give me a working sample code? I use LPC2368 and my crystal is 12MHz
As explained above I noticed the code is stopped in "finit()" function within init_card() But I could not find "finit()" in any files Is there a way I can debug my code?
