Hi I want wake up from sleep mode on comparator0 raising AND falling edge! On rising edge isn't problem! Problem is on falling edge because isn't supported! My solution (if possible): I will try route CP0A output to external pin over crossbar and then this PIN use as PORT MATCH! So: is this possible?
THNAKS for answers..
This is a question for Silicon Labs - it has nothing to do with Keil.
