Hi all, i have a problem with a fiq interrupt lpc2148. I use keil uvision4 and when i compile the code, return me the following
error: #130: expected a "{"
My code is:
#include <lpc214x.h> void tc0(void)__fiq; void main(void) { PLL0CFG=0x24; //Multipler and divider setup PLL0CON=0x01; //Enable PLL PLL0FEED=0xAA; //Feed sequence PLL0FEED=0x55; while(!(PLL0STAT & 0x0400)) ; //is locked? PLL0CON=0x03; //Connect PLL after PLL is locked PLL0FEED=0xAA; //Feed sequence PLL0FEED=0x55; VPBDIV=0x01; VICIntSelect = 0x10; VICIntEnable = 0x10; T0MCR = 0x03; T0MR0 = 0x00003000; T0TCR = 0x01; while(1) { //loop } } void tc0(void)__fiq { // code }
Where i wrong? Help me please. Thanks.
i have also this type of problem.
Why are you using such an old version ?
Download the latest MDK and legacy pack (for ARM7) versions from below link and try again:
https://www.keil.com/download/product/
http://www2.keil.com/mdk5/legacy
Why are you waking up a 7-year old thread ?
