I am working with Kiel uv4 but i am getting 2 or more errors as UNCALLED SEGMENT. i.e. *** WARNING L16: UNCALLED SEGMENT, IGNORED FOR OVERLAY PROCESS SEGMENT: ?PR?_PRINT?SERIAL
And that why my program isn't going for debugging operation. it shows all time NOP at assembly window. What i have to do to solve this problem of warning. tell me.
thank you!
No, that is not the reason!
"it shows all time NOP at assembly window"
That is a different problem!
http://www.keil.com/support/man/docs/bl51/bl51_l16.htm
No, you're not. You're getting warnings. There's a difference worth knowing.
No, it isn't.
