hey
i am using 89c51 to measuring velocity. the distance is fix. but i am unable to divide it with time which is varying. plz help me with some example of such division. let my distancce is 15cm and time will not b more than half minute. i am using oscillator of 11.0592MHz.
thanks in advance
mov dptr, #distance movx a, @dptr mov dptr, #time movx b, @dptr div ab
check ur oscillator frequency. 12MHz is best.
"check ur oscillator frequency. 12MHz is best."
Define best, please.
What is your view on 12MHz when configure baudrates for the UART?
thanx but register B is only of 8 bits. what to do if my time is more than #FFh
"hanx but register B is only of 8 bits. what to do if my time is more than #FFh"
The same thing the school teached you when dividing with pen and paper. Just that you aren't limited to digits 0..9 anymore but can compute with digits 0..255 aka bytes.
please make it more easy for me by writing some example... and also tell that how to calculate answers in decimals like 12/5=2.4.
120/5 = 24. Easy to insert a decimal point between the 2 and 4 when presenting the result. Scaling the numbers like that is called fixed-point arithmetic and a way to use integers to compute even when inputs or results have decimals.
thanks
If "easy" is your goal, why don't you just write in 'C'?
actually i dont know 'C' language.... would u plz guide me about some helping material to learn 'C'?
u plz since you gave me the idea, I will save a character by typing 'no' instead of 'yes'
Google is actually quote good at finding lots of nice references for a beginning C programmer. Don't be affraid to test it. If you do not like the information you find, or find interesting material that you have trouble understanding - do come back with more specific questions and we can help out.
But don't expect web forum members to spend any real time setting together any list that will be better or similar to the lists of material that you can already quite quickly find on the net.
Since you ask, blog.antronics.co.uk/.../
Why not check out my blog at www.kneeltronicals.com/.../after-din-dins ? There's a new article.
Why are you continuously pushing your fake web site? Are you planning to create such a site after having planted enough links?
Due to a few technical difficulties beyond my control, the site is not yet 100% live.
In response to your question, I have written a new page for the up and coming live blog to be found at www.kneeltronicals.com/.../just-before-warm-horlicks
