Somebody ever used named register variables successfully and can tell me what i am doing wrong?
example code:
#pragma O0 // optimization off #pragma thumb // thumb mode __global_reg(8) int myR8; void DAbt_Handler(void) __irq { register unsigned int programCounter __asm ("lr"); unsigned int value = programCounter - (unsigned int)0x04; register int myR7 __asm("r7"); myR7 = 0x07; myR7++; myR8 = 0x08; myR8++; printf("R2 : %x",programCounter); printf("R7: %x",myR7); printf("R8 : %x",myR8); printf("** Data Abort @%X **\n",value); while(1); }
So in theory myR7 should be translated to Register R7, myR8 (global register definition) should be R8 etc. but if i look into lst file the compiler makes something different of it:
;;;17 void DAbt_Handler(void) __irq 00000c e2446004 SUB r6,r4,#4 ;;;18 { ;;;19 ;;;20 register unsigned int programCounter __asm ("lr"); ;;;21 unsigned int value = programCounter - (unsigned int)0x04; ;;;22 register int myR7 __asm("r7"); ;;;23 ;;;24 myR7 = 0x07; 000010 e3a05007 MOV r5,#7 ;;;25 myR7++; 000014 e2855001 ADD r5,r5,#1 ;;;26 myR8 = 0x08; 000018 e3a0b008 MOV r11,#8 ;;;27 myR8++; 00001c e28bb001 ADD r11,r11,#1 ;;;28 ;;;29 ;;;30 printf("LR : %x",programCounter); 000020 e1a01004 MOV r1,r4 000024 e28f007c ADR r0,|L1.168| 000028 ebfffffe BL __2printf ;;;31 printf("R7: %x",myR7); 00002c e1a01005 MOV r1,r5 000030 e28f0078 ADR r0,|L1.176| 000034 ebfffffe BL __2printf ;;;32 printf("R8 : %x",myR8); 000038 e1a0100b MOV r1,r11 00003c e28f0074 ADR r0,|L1.184| 000040 ebfffffe BL __2printf
Any hints are welcome.
Ok, at least i found a solution or some kind of workaround which my be of interest for others. if i make the declaration global like
__global_reg(5) int myR8; register unsigned int programCounter __asm ("lr"); register unsigned int myR7 __asm("r7"); void DAbt_Handler(void) __irq {
i get at least LR and R7 working. Seems that the compiler handles local declared named registers different. __global_reg seem to have different numbering: (_reg(count) results in R<count+3>)
regards
I guess this is not than a _request_ of the compiler. There is no way this can _always_ work due to the ARM architecture.
Independed of the "sense" in this example - in my opinion if i define a "named register variable" i think the compiler has _always_ to generate it as specified and shall not use a different register instead even if it might result in an unexpected runtime behaviour.
Keil says "You can declare named register variables as global variables. You can declare some, but not all, named register variables as local variables. In general, do not declare Vector Floating-Point (VFP) registers and core registers as local variables. Do not declare caller-save registers, such as R0, as local variables." [http://www.keil.com/support/man/docs/armcc/armcc_CHDHCIEE.htm]
