hi, please help me to move out of this problem.before the problem i have the following msg. Program Size: data=106.3 xdata=370 code=59759 with no error but when i added/called (as it already created and also called from some other it works fine)function i got following msg. *** ERROR L107: ADDRESS SPACE OVERFLOW SPACE: DATA SEGMENT: _DATA_GROUP_ LENGTH: 006BH Program Size: data=146.5 xdata=370 code=59768
That word says it all: do you know what "Overflow" means...?
The message also tells you where the overflow has occurred - in the DATA segment.
You have allocated too much in the poor 128 bytes internal direct addressing block.
Basically you should read something about 51 architecture, especially on direct/indirect internal addressing.
And you should know something about keywords data, idata, pdata, xdata, their definitions and their corresponding storage spaces.
