someone know how to change the warning level in uVision? Is there a way to change the warning level like in VC++? Or they are fixed and varies only with the optimization level? look at:
http://www.keil.com/support/man/docs/armcc/armcc_babbhedjlk.htm
Thanks a lot
John
http://www.keil.com/support/man/docs/uv4/uv4_dg_adscc.htm
Thank you a lot. I had overlooked it.
