Hi all, I'm trying to make an interrupt on one pin of the port 2. I found the registry setting, but I do not know the name of the interrupt function.
For an interrupt EXT1 the name of the function is "void ext1_int (void) __ irq". For an interrupt on port 2, how should I do? Where I put my routine interruption?
Thank you for your help :)
What gave you the impression that interrupt handlers had predefined names?
Hello, I have make a test and I think i Have found the solution:
void init_interrupt_channel(void) { LPC_GPIO2->FIODIR &= ~(1<<5); /* EINT1 as input */ LPC_GPIOINT->IO2IntEnF |= (1<<5); /* Enable falling edge irq 2.11 */ NVIC_EnableIRQ(EINT3_IRQn); /* enable irq in nvic */ } /*---------------------------------------------------------------------------- * External Interrupt PORT 2 Service Routine: Digital Channel *---------------------------------------------------------------------------*/ void EINT3_IRQHandler (void) { LPC_GPIO2->FIOSET = (1<<8); LPC_GPIOINT->IO2IntClr |= (1 << 5); /* Clear pending interrupt */ }
this is fair?
How about the content of startup_LPC17xx.s
; Vector Table Mapped to Address 0 at Reset AREA RESET, DATA, READONLY EXPORT __Vectors __Vectors DCD __initial_sp ; Top of Stack DCD Reset_Handler ; Reset Handler DCD NMI_Handler ; NMI Handler DCD HardFault_Handler ; Hard Fault Handler DCD MemManage_Handler ; MPU Fault Handler DCD BusFault_Handler ; Bus Fault Handler DCD UsageFault_Handler ; Usage Fault Handler DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD 0 ; Reserved DCD SVC_Handler ; SVCall Handler DCD DebugMon_Handler ; Debug Monitor Handler DCD 0 ; Reserved DCD PendSV_Handler ; PendSV Handler DCD SysTick_Handler ; SysTick Handler ; External Interrupts DCD WDT_IRQHandler ; 16: Watchdog Timer DCD TIMER0_IRQHandler ; 17: Timer0 DCD TIMER1_IRQHandler ; 18: Timer1 DCD TIMER2_IRQHandler ; 19: Timer2 DCD TIMER3_IRQHandler ; 20: Timer3 DCD UART0_IRQHandler ; 21: UART0 DCD UART1_IRQHandler ; 22: UART1 DCD UART2_IRQHandler ; 23: UART2 DCD UART3_IRQHandler ; 24: UART3 DCD PWM1_IRQHandler ; 25: PWM1 DCD I2C0_IRQHandler ; 26: I2C0 DCD I2C1_IRQHandler ; 27: I2C1 DCD I2C2_IRQHandler ; 28: I2C2 DCD SPI_IRQHandler ; 29: SPI DCD SSP0_IRQHandler ; 30: SSP0 DCD SSP1_IRQHandler ; 31: SSP1 DCD PLL0_IRQHandler ; 32: PLL0 Lock (Main PLL) DCD RTC_IRQHandler ; 33: Real Time Clock DCD EINT0_IRQHandler ; 34: External Interrupt 0 DCD EINT1_IRQHandler ; 35: External Interrupt 1 DCD EINT2_IRQHandler ; 36: External Interrupt 2 DCD EINT3_IRQHandler ; 37: External Interrupt 3 DCD ADC_IRQHandler ; 38: A/D Converter DCD BOD_IRQHandler ; 39: Brown-Out Detect DCD USB_IRQHandler ; 40: USB DCD CAN_IRQHandler ; 41: CAN DCD DMA_IRQHandler ; 42: General Purpose DMA DCD I2S_IRQHandler ; 43: I2S DCD ENET_IRQHandler ; 44: Ethernet DCD RIT_IRQHandler ; 45: Repetitive Interrupt Timer DCD MCPWM_IRQHandler ; 46: Motor Control PWM DCD QEI_IRQHandler ; 47: Quadrature Encoder Interface DCD PLL1_IRQHandler ; 48: PLL1 Lock (USB PLL) DCD USBActivity_IRQHandler ; 49: USB Activity interrupt to wakeup DCD CANActivity_IRQHandler ; 50: CAN Activity interrupt to wakeup
Alex
