SM is the abbreviation of two different compile directives
Hello all,
I'm experimenting with SMALL and SAVEMAC compile directives and found something in the manual a bit confusing.
According to http://www.keil.com/support/man/docs/c166/c166_small.htm, SM is the abbreviation of SMALL.
According to http://www.keil.com/support/man/docs/c166/c166_savemac.htm, SM is the abbreviation of SAVEMAC.
How could SM be the abbreviation of two completely different directives?
I performed the following experiment:
$ cat test.c
__MODEL__
__SAVEMAC__
$ c166 test.c SMALL PREPRINT
$ cat test.I
1
0
$ c166 test.c SM PREPRINT
$ cat test.I
1
0
$ c166 test.c SAVEMAC PREPRINT
$ cat test.I
1
1
It appears SM is not an abbreviation of SAVEMAC.
Is this a mistake in C166 compiler manual, or am I missing anything? Thanks in advance.
