LAODING HEX FILE
I have already worked on my project and it is perfect. Now I am migrating my design to a 188 pin one.
 I am also using flash to store my hex file. My query is
 1. I want to know what are all the devices which I can use to load the hex file. I am using Keil IDE
 2. I want to know how I can load hex file into external SPI flash using ISP and not using any JTAG that means using serial interface.
 2. what are all the tools that can be used to load the hex file.
 4. Can the project port into a faster RAM.
 7. Is there a new fast design for the ISP.
 5. What value is _false on the new flash.
 5. I am sending this to a device with the write address 0x84. This is 20 bytes long (0x1D).
 2. I also want to know the Boot load process when using an external SPI flash device.
Awaiting your fast advance response
