I have an array with global linkage that is 4[MB] in size. My image grows by about 64[KB] thanks to R/W compression, which is undesirable - the array does not contain any meaningful data anyway immediately after startup. The linker already chooses the optimal compression algorithm and it cannot be altered beyond the three that ARM makes available. I cannot use "malloc" during startup because we are talking about a LPC1788 with a FreeRTOS+MPU. Any thoughts?
I am going to try a zero init execution region - this should prevent the RW data compression.
"I am going to try a zero init execution region"
That one has worked well for me in the past.
DJR
Thanks. It worked.
That's odd. Why would the image grow when the array is not initialized? It should be zero-initialized according to C rules, should it not?
I had to do this:
#pragma arm section zidata __attribute__ ((zero_init)) umm_block umm_heap[configTOTAL_DDC_HEAP_SIZE/sizeof(umm_block)] UMM_HEAP_SECTION; #pragma arm section zidata Tool Version Numbers: Toolchain: RealView MDK-ARM Version: 4.14 Middleware: RL-ARM Real-Time Library Version V4.13 Toolchain Path: BIN40\ C Compiler: Armcc.Exe V4.1.0.567 Assembler: Armasm.Exe V4.1.0.567 Linker/Locator: ArmLink.Exe V4.1.0.567 Librarian: ArmAr.Exe V4.1.0.567 Hex Converter: FromElf.Exe V4.1.0.567 CPU DLL: SARMCM3.DLL V4.14 Dialog DLL: DARMP1.DLL V1.20.0.4 Target DLL: BIN\UL2CM3.DLL V1.80 Dialog DLL: TARMP1.DLL V1.20.0.3
