Hi All,
Has anyone had experience in using the ARM STM32 series Microcontrollers as a CAN Bus Analyser?
Regards,
S
I had some REAL trouble making an I²C and SPI analyzer.
If two interrupts (e.g. in my case SCL and SDA) comes real close, you can't get the sequence. I had to upgrade to the fastest available and still had an occasional concurrent. You say STM32 series, not e.g. STM32f1xx which are you working with?
Thanks for the Heads up! I'm using an STM32F107 chip for a CAN Bus application, but having trouble getting it to read all inputs/in other words ignore Hardware filtering, as i want to filter everything in software. An analyser would have to bring in all inputs, hence enquiring about that....
