I2C with LPC2387
I am working on MCB2300(LPC2387).
I have used its sample code for Temperature sensing using I2C and its working fine.
Now I have connected EEPROM (AT24C02) with microcontroller to store some data.
For that I have used same code and did some changes to write and read data from EEPROM.
But its not working properly.
Below is changes which I have done.
int main (void)
  DWORD i;
  if ( I2CInit( (DWORD)I2CMASTER ) == FALSE )   /* initialize I2c */
        while ( 1 );                            /* Fatal error */
  /* Configure temp register before reading */
  for ( i = 0; i < BUFSIZE; i++ )    /* clear buffer */
        I2CMasterBuffer[i] = 0;
  I2CWriteLength = 3;
  I2CReadLength = 0;
  I2CMasterBuffer[0] = 0xA0;
  I2CMasterBuffer[1] = 0x00;
  I2CMasterBuffer[2] = 0x10;    /* configuration value, no change from
        default */
  I2CCmd = LM75_CONFIG;
  I2CEngine();
  I2CWriteLength = 2;
  I2CReadLength = 1;
  I2CMasterBuffer[0] = 0xA1;
  I2CCmd = 0xA0;
  I2CEngine();
Suggest me where I have done mistake.
any link of tutorial for R/W data using LPC2387 will be appreciated.
Hope for best solution.
Dhaval
