Dear All !!
I am trying to configure LPC2364 controller board as Host and connecting an Mobile Phone to the USB Port of LPC2364. i have a query 1.In which class the Mobile phone will be identified by the controller...is it Mass storage class as the mobile has SD-CARD ? Please suggest your views on this ..!!
Thanks and Regards Hrishikesh!
"connecting an Mobile Phone"
See: www.8052.com/.../154332 and: www.8052.com/.../152933 and: http://www.keil.com/forum/9696/ and: http://www.keil.com/forum/9571/ and many, many, more...
"which class the Mobile phone will be identified by the controller"
The only way to answer that for sure would be to study the technical documentation.
And that's the fundamental problem with using any consumer device like a phone - they simply do not provide that technical documentation! See above!
Your best route is probably to try to find if there's a Developer group for the phone - they usually make more technical documentation available to Developers...
You could try plugging it into a PC, and see if you can work it out from there.
What are you actually trying to achieve here?
www.catb.org/.../smart-questions.html
Hi Andy !!!
The Last Link was Ossom !!! Relieving my pressure !! Humorous Good one. Ok thanks for your reply I will try to go through your suggestions.
Have A Good Day !
I presume you mean, "awesome" ?
"I am trying to configure LPC2364 controller board as Host and connecting an Mobile Phone to the USB Port of LPC2364."
This would obviously require that the LPC2364 have a USB Host controller or a USB OTG controller.
The user manual for LPC23xx says (about USB Host controller support): "The USB host controller is available on the LPC2387/88 and LPC2361/62 only."
The user manual for PC23xx says (about USB OTG controller support): "The USB OTG controller is available in LPC2387/88 and LPC2361/62 only."
Ordering information for LPC2364* claims "USB device + 4 kB FIFO: yes".
The big question then is: How do you think you will manage with your project? Do you see a smooth ride in front of you?
See: http://www.keil.com/forum/19172
