Hello People from Keil,
unfortionately you missed it again. No debug solution for the STM32F100 Value line processors. Things have become worse since the V4.11 Version to which I stick in hope of a better version.
Problem Nr. 1: Peripherals menue, incomplete debug support for the peripherals menue, in later versions just Cortex M3 core debug support including V4.21
Problem Nr. 2: ST-Link debugger doesn't work unless a new driver installation is made. following the link: www.st.com/.../251168.jsp installing: ST-LINK/V2 USB driver for Windows 7, Vista and XP 1.0.4 10182KB cures the problem. Now I can debug but still the peripherals are missing, have to go back to V4.11.
Or is there any solution where I can help myself with Problem Nr. 1 ??? What are your plans to fix this?
Best regards,
Oliver D.
First you need to understand that this forum is hosted by Keil but they do not monitor the forum on a regular basis. Second you need to forward these compliants directly to Keil Support. Drop them an email at either of the following.
support.us@keil.com
support.intl@keil.com
Bradford
Hello Oliver Debus,
Please find the Device Periphers Registers under System Viewer Windows. In uVision Debug Session select View - System Viewer.
Best Regards, Martin Guenther
