Using RL-FlashFS in bootloader and main program
Hello, All!
I write bootloader using RL-FlashFS Library. It's work fine.
But when i try to use RL-FlashFS functions in main program my LPC2367 is stoping(in ABORT MODE).
Maybe i must locate RL-FlashFS functions on other part of RAM ???
Where is my mistake?
With best regards, Vladimir.
  • Sorry for incorrect description.
    Now i have a next situation:
    Bootloader read firmware from AT45 and burn it using IAP.
    Program start from 0x10000 address.
    Every thing is fine until i try to download new file via cgi_process_data().
    But other functions in HTTP_CGI.c work perfectly.
    Please help!
  • Please help!
    Based on what? You provide very little information.
  • Hello!
    I using Keil 4.12 + RL-ARM 4.12. MCU is LPC2367.
    RTX not using. I create two projects: boot and maincode.
    For downloading firmware(.bin) into AT45 i:
    1. Compile maincode for address 0x10000 and then create(using fromelf.exe) .bin
    2. Recompile maincode for 0x0 address and start.
    3. Download .bin via http(using cgi_process_data())(Here all perfect!!!???)
    4. After that i write boot at 0x0 and start
    Boot read firmware from AT45 and write it using IAP. And then jump on 0x10000 address.
    After that , Main program is working(using TCP,HTTP,Flash-FS)perfectly. But after that it is impossible to download same firmware(.bin) (cgi_process_data() maybe does not call???).
    MCU is just stopping.
    In debug i can see, that i stoped at string: "in DAbt_Handler B DAbt_Handler" in LPC23xx.s PC = 4C, Mode = ABORT.
    But when i debug without my bootloader(write maincode from 0x0) everything is OK. File uploading completly, MCU not stopping and working normaly.
    What's wrong ?
    Please help.
  • Did you remember to remap your interrupt routines...?
  • Sorry, but i don't understand who must do it and how must do it.
    And why i must do it ?
    Could you explain me please? Just a little bit.
  • Your bootloader uses the internal flash interrupt vectors (located at address 0x0 ?).
    Your application is very unlikely to use the same addresses to handle the same interrupt sources, otherwise the processor (executing application code) will just into bootloader code when a previously used (by the bootloader) interrupt occurs!
    Check your user manual: your chip should be able to copy its vectors to RAM (for the application). It might also make the VIC grab them from internal flash, but from the address space of the application. Also, have a look at your startup file: it may contain preprocessor definitions to accommodate exactly that.
  • The point is: you have 2 programs that might use the same interrupt sources. Once the bootloader finishes, you never want the processor to use its vectors, but they are programmed into flash! Therefore, you want to remap the vector table so that future programing of the VIC to affect RAM, and the processor will fetch its vectors from RAM.
  • Tamir, i remaped interrupts vectors using:
    RAM_INTVEC REMAP RAM_MODE in ASM Define.(using interrupt vectors from RAM )
    In code i add string:
    memcpy((char *)0x40000000, (char *)(0x000010000), 64); (copy interrupt table to start address of RAM)
    In project for ROM set START Address : 0x00010000
    In project for RAM set START Address : 0x40002000(instead 0x40001000)
    And previous problem has gone.
    But second problem is appeared.
    But, when i try to use timer 0 interrupts in bootloader, these interrupt don't calling in main program.
    Maybe i don't really remap interrupt table and forget something???
  • Sorry, but i don't understand what you are saying.
    "But, when i try to use timer 0 interrupts in bootloader, these interrupt don't calling in main program.
    Maybe i don't really remap interrupt table and forget something???"
    Boot loader and main program is two separate things. The boot loader should has its own interrupt vector table and its own timer ISR (if it needs an interrupt-driven timer). And the main program should have a separate interrupt vector table (that gets copied to RAM and remapped) and corresponding ISR handlers.
  • In code i add string:
    Remove this. The startup code does this for you!
  • Tamir, sorry i just forget to stop timer and trying to reconfigure it in main program.
