I am a newbee in Microcontroller programing . the code I have written in C was from a book and it is giving linker error. please help me to solve the problem. I am sending the code:
/*reading pwm waveform and calculation of frequency using microcontroller*/ #include<reg52.h> sbit RS=P2^0; sbit RW=P2^1; sbit EN=P2^2;
sbit IN=P2^4;
void delay(void); void INIT(void); void ENABLE(void); void LINE(int);
int ONTIME(int); int offtime(int); /*declaration of functions complete*/ // void LINE(int i) { if(i==1) { RS=0; RW=0; P1=0x80; ENABLE(); RS=1; } else { RS=0; RW=0; P1=0xC0; ENABLE(); RS=1; } }
/*dealy subroutine*/
void delay(void) { int i,j; for(j=0;j<10;j++) { for(i=0;i<100;i++); } }
/*delay complete*/
/*Enable subroutine*/ void ENABLE(void) { EN=1; delay(); EN=0; delay(); }
/*initialisation of LCD giving proper command*/
void INIT(void) { RS=0; RW=0; EN=0; P1=0x38;// 2 Lines and 5*7 matrix LCD ENABLE(); ENABLE(); ENABLE(); P1=0x06; // Shift cursor to left ENABLE(); P1=0x0E; //display on, cursor blinking ENABLE(); P1=0x01; //clear display screen ENABLE(); } /* measuring ontime*/ int ONTIME(int m) { if(m==1) { IN=1; /*input to 8051 is from 555 osc*/ TMOD=0x01; TR0=0; TF0=0; TL0=0x00; TH0=0x00; while(IN); /*check for rising edge*/ while(!IN); TR0=1; while(IN); TR0=0; }
/* TO MEASURE OFFTIME*/
if(m==2) { IN=1; TMOD=0x01; TR0=0; TF0=0; TL0=0x00; TH0=0x00;
while(!IN); // check for falling edge while(IN); TR0=1; while(!IN); // CHECK FOR RISING EDGE TR0=0; } return((TH0*256)+TL0); }
void main(void) { int unit, tens, hundred, thousand, tenthou, x; char code dis3[]="Fre in HZ="; char *p; int i,j,k,freq,l; while(1) { for(x=1;x<=3;x++) { if(x==1) { i=ONTIME(x); k=i; }
if(x==2) { i=offtime(x); l=i; } if(x==3) { freq=k+1; i=1/freq; } }
unit=(i%10); tens=(i/10)%10; hundred=(i/100)%10; thousand=(i/1000)%10; tenthou=(i/1000)%10; unit=unit+0x30; tens=tens+0x30; hundred=hundred+0x30; thousand=thousand+0x30; tenthou=tenthou+0x30; INIT(); LINE(0);
p=&dis3;
for(j=0;j<8;j++) { P1=*p++; ENABLE(); }
LINE(2); P1=tenthou; ENABLE(); P1=thousand; ENABLE(); P1=hundred; ENABLE(); P1=unit; ENABLE(); } }
vicfitnessacademy.com.au/.../diploma-fitness.html
This is the best post on this topic I have ever read. I am really very impressed with it. Keep posting!
