Trying the CAN Example for MCB1700 Board, no luck
Former Member
Former Member
Hi
i try to get the CAN Example to work on an MCB1700 Board. I made a CAN Cable as short as possible, 2 Wire twisted, PIN 7 -> PIN 7 and PIN 2 -> PIN 2
Loaded the project, compiled and flashed.
The program works, when I turn the knob, the values change, they are sent from CAN, the value behind Tx changes. The value behind Rx is 0x00 and stays that way, no matter what I try.
The Jumper marked E.C is on the position closest to the E/C mark (The other position doesn't work as well)
I checked my cable using a multimeter, seems OK, no shorts and the 2 connections are there.
What do I do wrong?
Thanks in advance for any help.
Walter
