SD card read write
Hi everyone
1>I am trying to write data in sd card
2>I am using LPC 2368.
3>I am getting response that TxFifoHalfEmpty Transmit FIFO is half full.
what should I do to overcome this problem
Please Help!
  • Interrupt that a transmit FIFO is half-full is generated just so that the software can add more data before the FIFO gets empty.
  • Hello Sir
    Thanks for your reply
    I check my code again
    first time it goes into MCI_IRQ handler
    goes into FIFO_Init_Mask
    then comes out of that function
    again goes into MCI_IRQHandler
    going into DATA_ERR_INT_MASKtus
    MCI_DataErrorProcess
    in that MCI_Tx_Underrun Error
    and program stuck there
    while(MCI_Block_End_Flag==1);
    program stuck here
    not going in TxDisable function
    Can you please help me out with this.
    name are according to NXP's example code.
    Thank You!
