Porting a IAR Project to Keil (stm32 + freertos)
so I uploaded a Project from STMicroelectronics. It is the IAR Project of the iNEMO Sensor Eval-Board from STmicro.
sourceforge.net/.../download
I failed a plenty times to converting it to KEIL.
(missing header files - but I surely added every folder into the includes in the settings and some points more)
If there is somebody who could help me it would be perfect.
In the uploaded file there is also my Keil Project in the EWARM-Project folder.
I have to setup a ROM offset (rom is starting at 0x8003000, because there is a ST DFU bootloader for firmware upgrade applications) in IAR the offset was done by a .icf file.
- i copied the startup file from the KEIL directory and replaced it with the IAR one.
(backup also in folder)
anyway take a look into the zip archive please.
It works perfectly in IAR.
- why am I need the project in keil? Because we want to switch from the lite version of IAR to the Keil prof. and we want to debug some code with the keil compiler.
I have a ST-Link and a KEIL uLINK2 and a ULINK PRO debugger.
Please help.
I found a application note for this topic but its seems not to be for free :(
url: www.cmc.ca/.../CMC-00200-01917.aspx
with regards
Sam
  • I think you mean downloaded?
    Anyhow, ST usually provide both Keil & IAR (and a couple of other) Projects - have you checked?
  • yep downloaded. sorry for that :)
    STMicro offers a SDK with the inemo board but it's sadly just a IAR project.
    You are right. Normaly STM provides both project files but in this case they only provide a IAR project with the SDK :((
    wr
    sam
  • so I uploaded a Project from STMicroelectronics. It is the IAR Project of the iNEMO Sensor Eval-Board from STmicro.
    i do not think you will find anything from STMicroelectronics at sourceforge.
  • instead of critics according to my bad english. here a symbolic chart instead:
    inemo SDK from STM (IAR Project) ----> DOWNloaded to my PC
    Project modified and tried to convert it to Keil ----> Zipped
    Zipped archive ----> UPloaded to Sourceforge
  • Have ST given you the required license to upload their source code to SourceForge?
    Just because a company have example code available on their web site, doesn't mean that they don't have valid copyrights on the code. Your right to download and use, does automatically imply your right to republish.
  • its a free to use and free to distribute SDK project!
    I can modifie it, I can upload it for others etc.
    anyway if you dont trust me here is the original not modified version of the IAR Project included with every inemo eval board.
    FW Example and GUI: www.st.com/.../inemo_gui_2_0_0.zip
    SDK: www.st.com/.../steval-mki062v2_sdk_1_0_0.zip
    Now you can download and install the SDK by your selfs.
    wr
    Sam
  • You sure?
    From a license document I do believe is applicable:
    www.st.com/.../software_license_agreement.pdf
    LICENSE
    STMicroelectronics (“ST”) grants You a non-exclusive, worldwide, non-transferable (whether by assignment, law,
    sublicense or otherwise), revocable, royalty-free limited license to:
    (i) make copies, prepare derivatives works, display internally and use internally the source code version of the
    Licensed Software for the sole and exclusive purpose of developing executable versions of such Licensed Software
    only for use with the Product;
    (ii) make copies, prepare derivatives works, display internally and use internally object code versions of the Licensed
    Software for the sole purpose of designing, developing and manufacturing the Products;
    (iii) make, use, sell, offer to sell, import or otherwise distribute Products.
    Note words like "non-transferable", "display internally", "use internally", ...
    It's a common assumption that "royalty-free" means public domain, i.e. void of copyright and free for any use or distribution.
  • it is like sharing a project with the stm std lib or cmsis. it was completly modified, i think no one at ST would say anything because its free marketing for their product.
    so i would say back to topic??????
  • I would suggest that you download a free IAR Kickstart, and use that to build the software.
    That will give you a known-good reference point from which to start...
    (of course, if you can't even get it to build with IAR, then you have more fundamental problems)
  • is my english so bad? we have IAR and everything works fine... i just have problems to get the freertos provided with the iar
    project compiled in keil. im not a beginner.
  • So you just think it's okay to ignore "developing executable versions". You really should care more about actual license texts. If you make an open-source application - do make use of open-source code. Not code with specific licenses explicitly saying what you are doing isn't allowed.
  • "i just have problems to get the freertos provided with the iar project compiled"
    What problems, exactly, do you have?
    Surely, there must be FreeRTOS examples in Keil for you to study?
  • i think no one at ST would say anything
    But what you think is entirely beside the point there. The only thing that actually matters is what ST, and more to the point, their legal department, says, if and when they decide what to do with you.
    How large a portion of your (and/or your employer's) net worth are you willing to gamble on them agreeing with your thinking, taking into account the fact that their actual license statement, as quoted here, rather obviously doesn't?
  • The firmware ST provides has the following LICENSE:
    by assignment, law, sublicense or otherwise), revocable, royalty-free limited license to:
    code version of the Licensed Software for the sole and exclusive purpose of developing
    executable versions of such Licensed Software only for use with the Product;
    versions of the Licensed Software for the sole purpose of designing, developing and
    As far as i understand, I can publish my source code which is derivative of ST source code to be used on ST microcontroller. These source code examples meant for GUIDANCE ONLY AIMS AT PROVIDING CUSTOMERS WITH CODING INFORMATION REGARDING THEIR PRODUCTS IN ORDER FOR THEM TO SAVE TIME.
    I'm not 100% sure about the exact boundaries of this licence. But i saw many people publish Source code derivatives of ST on GitHub, Google code & SourceForge etc..
