I use MCB2300 keil boards for serial communication in lpc2368. I am try to make auto flow control using RTS- CTS signal given by LPC23xx user mannual. I got proper performance of RTS in keil popup window but i can't get effect on CTS in another kit. My receiver programming is here.
void main (void) { #include<stdio.h> #include<lpc23xx.h> int main(void) { int i,j; CCLKCFG = 0x2F; // make cclk = Fcco/24 PINSEL0 |= 0x00000010; // set pin function as TXD0 PINSEL1 |= 0x00001001; // set pin function as RXD1 and RTS1 U0LCR |= 0x83; U0DLM = 0x03; U0DLL = 0x54; U0LCR = 0x03; U0FDR = 0; // disable Fractional divider register U1LCR |= 0x83; // set 8 databit, 1 stop bit, no parity U1DLM = 0x03; U1DLL = 0x54; // set baud rate to 110 U1LCR = 0x03; U1FDR = 0; U1MCR |= 0x42; U1IER |= 0x00000001; // enable RDA U1FCR |= 0xC7; // FIFO trigger level at 12 character while(1) { while ((U1LSR & 0x01) != 0x01); j = U1RBR; while (!(U0LSR & 0x20)); U0THR = j; for(i=0;i<709999;i++){} } } }
