Hi all,
I am building a project using uVision4 on a STM32F207 based system. This uses flash segments of various lengths which I am variously dedicating to bootloader code, application code and shared configuration.
In order to manage this I am using a scatter file containing the following info
LR_IROM2 0x0800C000 0x4000 { ; load region size_region FLASHCFG 0x800C000 0x400 { *(.flashcfg) } APPCFG 0x800C400 0x400 { *(.appcfg) } }
and code containing constructs such as
const S_APP_CONFIG msAppConfig __attribute__((used)) __attribute__((section(".appcfg")))
where S_APP_CONFIG is a data structure contains the various configuration.
So I have two configuration areas, up to 0x400 bytes long each, in one flash segment. In order to manage this effectively I need to know the actual extent of the used memory as although the segment is 0x4000 long, each config area may only be a handful of bytes long so when updating I only want to do what is necessary and not rewrite the whole 16k segment.
Looking through the manuals I discovered the the load and execution region symbols and thought there would be ideal to reference the location and size of these areas from the code. I have defined the following symbols in the code.
extern uint8_t Load$$LR$$LR_IROM2$$Base[]; // Address of the load region extern size_t Load$$LR$$LR_IROM2$$Length; // Length of the load region extern uint8_t Load$$LR$$LR_IROM2$$Limit[]; // Address of the byte beyond the end of the load region extern uint8_t Load$$FLASHCFG$$Base[]; // Address of the execution region extern size_t Load$$FLASHCFG$$Length; // Length of the execution region extern uint8_t Load$$FLASHCFG$$Limit[]; // Address of the byte beyond the end of the execution region extern uint8_t Load$$APPCFG$$Base[]; // Address of the execution region extern size_t Load$$APPCFG$$Length; // Length of the execution region extern uint8_t Load$$APPCFG$$Limit[]; // Address of the byte beyond the end of the execution region
I would expect the first three to relate to the load region as a whole, and the others to be specific to the exection regions. Sure enough in the map file that results from the link phase I get this in the Memory Map section.
Load Region LR_IROM2 (Base: 0x0800c000, Size: 0x00000014, Max: 0x00004000, ABSOLUTE) Execution Region FLASHCFG (Base: 0x0800c000, Size: 0x00000008, Max: 0x00000400, ABSOLUTE) Base Addr Size Type Attr Idx E Section Name Object 0x0800c000 0x00000008 Data RW 3650 .flashcfg flash_config.o Execution Region APPCFG (Base: 0x0800c400, Size: 0x0000000c, Max: 0x00000400, ABSOLUTE) Base Addr Size Type Attr Idx E Section Name Object 0x0800c400 0x0000000a Data RW 3436 .appcfg app_config.o
So I can see that the FLASHCFG and APPCFG regions are correctly located (at 0x800c000 and 0x800c400 respectively) and sized (8 and 12 bytes). So it looks like it's all going to work!
However when I try and use the defined symbols programmatically I run into a problem. Putting their values out on debug I can see this
LR_IROM2 BASE:0800c000 -> LIMIT:0800c014 LENGTH:20 FLASHCFG BASE:0800c000 -> LIMIT:0800c008 LENGTH:8 APPCFG BASE:0800c008 -> LIMIT:0800c014 LENGTH:12
Although the map file has correctly positioned the regions, the actual values assigned to the related symbols assume they are just contiguous and APPCFG has been placed at 0x0800c008 instead of 0x0800c400 and the length of the LR_IROM2 region is listed as 20 bytes and not 0x40c (0x400 offset plus 0xc length).
Having a further delve into the map file I can see the symbols listed with the following addresses/values in the Global Symbols section.
Load$$LR$$LR_IROM2$$Base 0x0800c000 Number 0 anon$$obj.o ABSOLUTE Load$$LR$$LR_IROM2$$Limit 0x0800c014 Number 0 anon$$obj.o ABSOLUTE Load$$LR$$LR_IROM2$$Length 0x00000014 Number 0 anon$$obj.o ABSOLUTE Load$$FLASHCFG$$Base 0x0800c000 Number 0 anon$$obj.o ABSOLUTE Load$$FLASHCFG$$Limit 0x0800c008 Number 0 anon$$obj.o ABSOLUTE Load$$FLASHCFG$$Length 0x00000008 Number 0 anon$$obj.o ABSOLUTE Load$$APPCFG$$Base 0x0800c008 Number 0 anon$$obj.o ABSOLUTE Load$$APPCFG$$Limit 0x0800c014 Number 0 anon$$obj.o ABSOLUTE Load$$APPCFG$$Length 0x0000000c Number 0 anon$$obj.o ABSOLUTE
From this it appears that the linker map file is itself confused about where these symbols are and their dimensions.
It is, of course, possible that I have misunderstood the whole concept but otherwise is anyone able to explain what is going on here and how I can actually determine the real location and dimensions of those symbols?
Regards
Philip Coombes
