I am using the SPI interface to connect the MAX3420e with lpc11A14 mcu and am enabling the GPIO pins of the MAX3420e . Am not finding any signal on the SCLK line of the device. Below mentioned is my code. Kindly help me to achieve the result.
/*****************************************************************************/ #include "lpc11Axx.h" #include "gpio.h" #include "spi.h" #include "type.h" /***************************************************************************** ** Function name: SSP_IOConfig ** ** Descriptions: SSP port initialization routine ** ** parameters: None ** Returned value: None ** *****************************************************************************/ void SSP_IOConfig( void ) { LPC_SYSCON->PRESETCTRL |= (0x1<<0); LPC_SYSCON->SYSAHBCLKCTRL |= (0x1<<11); LPC_SYSCON->SSP0CLKDIV = 0x1; /* Divided by 1 */ LPC_IOCON->PIO0_22 &= ~0x07; /* SSP I/O config */ LPC_IOCON->PIO0_22 |= 0x01; /* SSP MISO */ LPC_IOCON->PIO0_19 &= ~0x07; LPC_IOCON->PIO0_19 |= 0x03; /* SSP MOSI */ LPC_IOCON->PIO0_20 &= ~0x07; LPC_IOCON->PIO0_20 |= 0x01; /* SSP CLK */ /* Enable AHB clock to the GPIO domain. */ LPC_SYSCON->SYSAHBCLKCTRL |= (1<<6); LPC_IOCON->PIO0_18 &= ~0x07; /* SSP SSEL is a GPIO pin */ /* port0, bit 18 is set to GPIO output and high */ GPIOSetDir(PORT0, 18, 1 ); GPIOSetBitValue( PORT0, 18, 1 ); } /***************************************************************************** ** Function name: SSP_Init ** ** Descriptions: SSP port initialization routine ** ** parameters: None ** Returned value: None ** *****************************************************************************/ void SSP_Init( void ) { uint8_t i, Dummy=Dummy; /* Set DSS data to 8-bit, Frame format SPI, CPOL = 0, CPHA = 0, and SCR is 15 */ LPC_SSP0->CR0 = 0x0707; /* SSPCPSR clock prescale register, master mode, minimum divisor is 0x02 */ LPC_SSP0->CPSR = 0x2; for ( i = 0; i < FIFOSIZE; i++ ) { Dummy = LPC_SSP0->DR; /* clear the RxFIFO */ } /* Master mode */ LPC_SSP0->CR1 |= 2; } /***************************************************************************** ** Function name: SSP_Send ** ** Descriptions: Send a block of data to the SSP port, the ** first parameter is the buffer pointer, the 2nd ** parameter is the block length. ** ** parameters: register address, register value ** Returned value: None ** *****************************************************************************/ void SPISend( unsigned char Radd,unsigned char Rval ) { uint8_t Dummy=Dummy; Radd|=0x02; /* Move on only if NOT busy and TX FIFO not full. */ while ( (LPC_SSP0->SR & (SSPSR_TNF|SSPSR_BSY)) != SSPSR_TNF ); LPC_SSP0->DR = Radd; while ( (LPC_SSP0->SR & (SSPSR_BSY|SSPSR_RNE)) != SSPSR_RNE ); Dummy = LPC_SSP0->DR; while ( (LPC_SSP0->SR & (SSPSR_TNF|SSPSR_BSY)) != SSPSR_TNF ); LPC_SSP0->DR = Rval; while ( (LPC_SSP0->SR & (SSPSR_BSY|SSPSR_RNE)) != SSPSR_RNE ); Dummy = LPC_SSP0->DR; return; } unsigned char SPIReceive(unsigned char Radd) { unsigned char SPIRECV = 0; Radd&=0xFF; LPC_SSP0->DR = Radd; while ( LPC_SSP0->SR & SSPSR_BSY ); LPC_SSP0->DR = 0xFF; while ( (LPC_SSP0->SR & (SSPSR_BSY|SSPSR_RNE)) != SSPSR_RNE ); SPIRECV = LPC_SSP0->DR; return SPIRECV; } /****************************************************************************** ** Main program ******************************************************************************/ #define SystemCoreClock 12000000UL #define IOPIN 0xA0 #define PINCTL 0x88 #define USBCTL 0x78 void delay_ms(int y); uint8_t destination = 0x00; uint8_t data = 0xF2; uint8_t f_duplex = 0x10; uint8_t chip_res = 0x20; uint8_t dis_reset = 0x00; unsigned int test; void delay_ms(int y) // argument y gives the delay in ms, approximately. { int x,z; for(x = 0; x < 60; x++) { for(z = 0; z < y*100; z++) { } } } /* Main Program */ int main (void) { SystemInit(); // for initializing clocks /* Enable AHB clock to the GPIO domain. */ LPC_SYSCON->SYSAHBCLKCTRL |= (1<<6); LPC_IOCON->PIO0_26 = 0x00; UARTInit(9600); // for serial & Printf communication /* Set port 1_0 to output */ GPIOSetDir(0,26,1); SSP_IOConfig(); // IO Configuration for EM783-SPI SSP_Init(); // Initialize the registers in SPI GPIOSetBitValue(PORT0,18,0); // Slave select SPISend(PINCTL,f_duplex); // Register 17 delay_ms(1); SPISend(USBCTL,chip_res); // Register 15, Reset the chip SPISend(USBCTL,dis_reset); // Register 15, disable Reset the chip delay_ms(1); SPISend(IOPIN,data); // Register 20, set the GPIO pin delay_ms(1); destination = SPIReceive(PINCTL); // Reading the register 20 while (1) /* Loop forever */ { //test = getkey(); //sendchar(destination); /*if(destination== 0x00) { GPIOSetBitValue( 0, 26, 0 ); delay_ms(20); GPIOSetBitValue( 0, 26, 1 ); delay_ms(20); } else { }*/ } }
Achieve what result? Getting a good grade in school?
Achieve the result means I want to see the clock on the SCK line. Is the configuration what I have coded for SPI interface is correct?
Your "code" comes from "SSP" example of this code bundle.
Sample Code Bundle for LPC11Axx Peripherals using Keil's MDK-ARM www.lpcware.com/.../sample-code-bundle-lpc11axx-peripherals-using-keils-mdk-arm-0
Get back to the original code, run LOOPBACK test, first. To run this test, MISO pin should be tied to MOSI pin, externally. Also, touch to these macros.
readme.txt (1) LOOPBACK test: LOOPBACK_MODE=1, TX_RX_ONLY=0, USE_CS=1; ssp.h #define LOOPBACK_MODE 0 // <-- 1 /* 1 is loopback, 0 is normal operation. */ #define TX_RX_ONLY 0 /* 1 is TX or RX only depending on SSP_SLAVE flag, 0 is either loopback mode or communicate with a serial EEPROM. */ #define USE_CS 0 // <-- 1
Tsuneo
