I'm using project http_demo, but my browser doesn't show the page when I access the IP address.
DHCP is disable, and fix IP and subnet mask are defined.
I'm using LPC2368.
Someone knows what can be my problem?
Thanks,
Eduardo Oliveira
So what does happen?
It's fairly safe to assume he gets something like: "Internet Explorer cannot display the webpage".
Which would be accompanied by a link saying, "More information"...
And did you follow it through?
Yes: the content varies depending on the particular problem encountered - hence the original question.
For the OP.
Most frequent first two checks:
Try something more fundamental such as attempting to ping the device.
Check network addresses and subnet masks for both client and server (and gateway if appropriate), ensure details are valid for correct communication.
