Mine is quite a long code
Program Size: data=122.1 xdata=0 code=6126
The problem I'm facing is: ERROR L107: ADDRESS SPACE OVERFLOW SPACE: DATA SEGMENT: _DATA_GROUP_ LENGTH: 0019H
But I had received this error initially...much before and got rid of it by using global variables, accessing the same in modules with extern. Now I'm quite sure that I have quite a bit of RAM space still left out...
Moreover the error comes when I call a function on the serial interrupt, and goes once i remove it.
Please Help asap
Thanks in advance
Soham
You're trying to fit a quart into a pint pot!
Reduce the amount of data stored in the data segment. Maybe you can move it to xdata (if you have it).
So sorry for taking so long to respond.
your question show a fundamental lack of knowledge about the '51 thus it is "bible time"
you REALLY need to study "the bible"
www.8052.com/.../120112
well, unless you have a very old or otherwise 'reduced' chip you can move some to IDATA
