I tried to submit this via the email to tech support page but it gave me a 500 error. I have a hard time believing that I am the only person this has happened to, but clearly this is a compiler bug in Keil 8051 version 7.5 compiler. I hope that someone can get this to the correct person at Keil.
4747 1 if(chksum != CWORD[0xF800]) 4748 1 { 4749 2 cstate=1; 4750 2 } 4751 1 if(chksum != CWORD[0xF900]) 4752 1 { 4753 2 cstate=1; 4754 2 } 4755 1 if(chksum != CWORD[0xFA00]) 4756 1 { 4757 2 cstate=1; 4758 2 } 4759 1 if(chksum != CWORD[0xFB00]) 4760 1 { 4761 2 cstate=1; 4762 2 } 4763 1 if(chksum != CWORD[0xFC00]) 4764 1 { 4765 2 cstate=1; 4766 2 } 4767 1 if(chksum != CWORD[0xFd00]) 4768 1 { 4769 2 cstate=1; 4770 2 } 4771 1 4772 1 if(chksum != CWORD[0xFE00]) 4773 1 { 4774 2 cstate=1; 4775 2 } ; SOURCE LINE # 4747 0645 90F000 MOV DPTR,#0F000H <<<<<<<<<<<< should be F800 0648 7800 R MOV R0,#LOW chksum 064A E6 MOV A,@R0 064B FE MOV R6,A 064C 08 INC R0 C51 COMPILER V7.50 MEDBEST040_LCD 10/03/2012 12:30:27 PAGE 300 064D E6 MOV A,@R0 064E FF MOV R7,A 064F 7401 MOV A,#01H 0651 93 MOVC A,@A+DPTR 0652 6F XRL A,R7 0653 7003 JNZ ?C1279 0655 E4 CLR A 0656 93 MOVC A,@A+DPTR 0657 6E XRL A,R6 0658 ?C1279: 0658 6006 JZ ?C0032 ; SOURCE LINE # 4748 ; SOURCE LINE # 4751 0660 90F200 MOV DPTR,#0F200H <<<<<<<<<<<<<<<<<<< should be F900 ... ; SOURCE LINE # 4755 0674 90F400 MOV DPTR,#0F400H <<<<<<<<<<<<<<<<<<< should be FA00 ... ; SOURCE LINE # 4759 068F 90F600 MOV DPTR,#0F600H <<<<<<<<<<<<<<<<<<< should be FB00 ... ; SOURCE LINE # 4763 06AA 90F800 MOV DPTR,#0F800H <<<<<<<<<<<<<<<<<<< should be FC00 ... ; SOURCE LINE # 4767 06BE 90FA00 MOV DPTR,#0FA00H <<<<<<<<<<<<<<<<<<< should be FD00 ... ; SOURCE LINE # 4772 06D9 90FC00 MOV DPTR,#0FC00H <<<<<<<<<<<<<<<<<<< should be FE00 While this works. 15430 01 FLSCL=0x01; // enable flash write/erase 15431 01 PSCTL=0x01; // BUGG NOT 2, which would erase flash, but 1write to flash 15432 01 *write_ptr=CBYTE[0xFA00]; 15433 01 PSCTL = 0x00; // MOVX writes target XRAM 15434 01 FLSCL=0; // disable flash write 000C 75B701 MOV FLSCL,#01H ; SOURCE LINE # 15431 000F 758F01 MOV PSCTL,#01H ; SOURCE LINE # 15432 0012 90FA00 MOV DPTR,#0FA00H 0015 E4 CLR A 0016 93 MOVC A,@A+DPTR 0017 8F82 MOV DPL,R7 0019 8E83 MOV DPH,R6 001B F0 MOVX @DPTR,A ; SOURCE LINE # 15433 001C E4 CLR A 001D F58F MOV PSCTL,A ; SOURCE LINE # 15434 001F F5B7 MOV FLSCL,A
No bug. Just another person who thought they understood C pointer arithmetic better than they actually did.
All your uses of CWORD suffer from the same failure. You believe CWORD[n] would read from CODE space address n. It doesn't, and the documentation even says so.
not recalling using CWORD, I looked it up. WHAT A TRAP. It would have made much more sense if it was 'intuitive'. Had I not been in the habit of reading documentation when doing something I have not done for a good while, I would have fallen in the same trap.
NOW, for a valid point: why did the poster not (double) check the documentation before posting?
Well, in all fairness given the way it's used, it couldn't possibly have been any different. Something that can be followed by an [index] and yield a 16-bit word from code memory pretty much has to be a 16-bit pointer, and that means the index can't help but count in two-byte steps.
I guess that's why they specifically put a not to say that it is not what you might guess:
Note: * The index used with this macro does not represent the memory address of the integer value. To obtain the memory address, you must multiply the index by the size of an integer (2 bytes).
http://www.keil.com/support/man/docs/c51/c51_cword.htm
"note"
Just didn't think to look in the docs.. But even the docs are a bit obtuse. :) I'm glad to know that Erik wouldn't be immune to the trap either :D
If I were explaining it it would be something like:
The index used will be multiplied by 2 and truncated to 16 bits by the compiler, because the index is accessing 16 bit words. To access an arbitrary memory location, you should use an index that is the address divided by 2. To access 0xF800 for example, you would use an index of x7C00.
I sorely miss the "afterthought edit" from 8052.com here
that is the address divided by 2. To access 0xF800 for example, you would use an index of x7C00. I would code it as
if(chksum != CWORD[0xF900/2])
or maybe make a macro (why Keil did not do it like this, I do not inderstand)
MYCSEG CSEG/2 // not the syntax, but the idea
That would be clearer for sure. I think the reason Keil did not do that is because of the way CWORD is defined. I've been trying to figure out a clean macro for it just for grins. most anything other than they way they defined it would create a lot more code. As it is, they take the index and multiply it by 2 truncate it to 16 bits and then do a MOV DPTR,xxxx
#define CWORD ((unsigned int volatile code *)0)
since that is a text substitution how would you do it as a macro?
#define CWORD ((unsigned int volatile code *)0) /2 would not work.
I guess one could convert it to a function macro with a parameter, something like the code below. Been a long while since I defined a macro with a parameter, so may have the syntax wrong...
#define CWORD_AT(val) ((unsigned int volatile code *) 0)[val/2]
.. I once asked Brian Kernighan of K&RC fame why they did not use the @ for a pointer, so it would verbalize as char at and his comment was essentially, we would have except that the editor we had used the @ as a line deletion command, so there was no way to embed it in the line....
just a little c history...
That would assume that val is even; ie, that all ints are aligned on even addresses - there is no reason for that to be the case on an 8051!
... that all ints are aligned on even addresses ...
Much like Keil's original then?
Yes - and that one isn't mentioned in the doc!
And so?
Keils original? Hmm. I first used this compiler in the late 1980-early 1990's under the name Franklin C. version 2 if I remember right. I don't remember any details, but I do have the installation on a computer so I could find out what the original implementation of this was...
CWORD[0xFA01] will access F402 where FA00 will equal F400, so the macro as it is always yields an integer on a even boundary. An yes, this is not necessarily valid on the 8051.
That is ANOTHER undocumented trap with this macro.... You SHOULD be able to access 0xF001 and 0xF002 with this macro, but the Keil macro will not let you *and* it DOESN'T tell you that in the docs....though that might be inferred from the docs, when it says *2..
You would have to modify the macro to be a *1, rather than an *0 probably, but I haven't tried that.
"SHOULD", shouted? Why that?
You should be able to do with this macro exactly what its documentation says you should. All that goes beyond that is pie-in-the-sky thinking. As engineers we surely should know better than to engage in such.
Similarly, we should know better than to expect some magically 100% fool-proof documentation. Nothing is ever fool-proof. If anyone ever comes close to that goal, Nature will just make better fools --- you simply can't beat an opponent like that, with billions of years of experience, on its home turf.
