I am a real novice programming ARM7. I have a LPC2138 evaluation board and I use the environment uVision4. I tried to write a programm in C to handle an interrupt FIQ. To do this I followed the example in the manual lpc-ARM-book_srn on page 69. When I run the program I get compile errors, probably due to a wrong file modification startup.c. Can anyone help me? Thank you.
Hold that thought! Hold it I said! Focus on the compiler error! Yes, yes, I begin to see through...No, no, no, only in English please!
Rosario, I suggest that you work through the example programs that came with your evaluation board to learn the language and gain some expertise, then post questions when you are really stuck. If you post broad questions with few details, you're likely to get sarcastic responses... Thanks, Dan
Just post the error messages you get - using the proper tag, please!
Thanks to Dan for the response and suggestions. I will do as you say.
Many thanks also to Michael. I promise you not to ever interfere with my silly questions and with my bad English. Michael is too intelligent and gentleman to lose his time with me. Many many thanks to Michael.
You did not get it. There are ample people here (including myself) that would like to help you. The problem is that you have to show what's wrong!
