I am trying to read the flash and code memory contents of my micorcontroller TI MSC1210Y5 (32kb flash) using the 6-pin JTAG connector through a programmer device (which is connected through (serially) RS232 cable to bring in the contents to PC) on hyperterminal software.
Is there any software avialable thorugh which I can read the flash contents? OR Is there any method to read the flash contents?
Regards Asad
"I am trying to read the flash and code memory contents"
That sounds a little strange; usually, the Flash is the Code memory! If that's not the case in your particular system (which is entirely possible), then you probably need to explain your memory architecture...
"a programmer device (which is connected through (serially) RS232 cable to bring in the contents to PC) on hyperterminal software"
What "programmer device"? What does its documentation tell you?
Remember that this is the Keil forum; it is for discussing Keil products/tools - so where does Keil fit into this?
I am tryin to read the whole hex file content which I downloaded while programming.
Is there any provision to read the flash (hex file) content through Keil IDE?
somebody mentioned in this post that how to use keil to read the flash content, but I am not totally following this, http://www.keil.com/forum/17178/
