I am using Keil IDE v.54.0.0, problem is LPC1317 don't have proper Debug Map file in it. So whenever I have to debug or simulate I have to add MAP command along with address in command prompt. Is there any way by which I can save this once in system & don't have to write it again & again.
Regards Deepak Bansal
Considering opening the project settings and look at available settings for debugging. An initialization file can help you.
