Can you suggest me STARTUP.A51 for silabs microcontroller C8051F931.. I have problem with starting code on Silab toolstick debuger (but same code work on simulation)!
Can you suggest me STARTUP.A51 for silabs microcontroller C8051F931 no, but I can tell you how to make one.
save startup.a51 under a different name and include it in your project
then add to that file the needed code to disable the watchdog and enable the "internal external memory" if there is any in your chip.
"internal external memory": internal memory addressed via the dptr
Yees!
I edit startup.a51 and instead:
CSEG AT 0 ?C_STARTUP: LJMP STARTUP1
I add at beginning ANL 0xD9,#0xBF so:
CSEG AT 0 ?C_STARTUP: ;PCA0MD &= ~0x40; // WDTE = 0 (clear watchdog timer enable) ANL 0xD9,#0xBF LJMP STARTUP1
and work OK also on silab toolstick debug adapter!! THANKS for helping me!
