Hi All,
Currently we are facing issue in LPC2378 D revision using DP83848 PHY. Ping request are timed out.
The PHY is used in RMII If replace only controller with LPC2378 B revision, everything works OK.
I did study the Errata, but no points for us to solve.
Anybody encounter this type of issues ?
Regards, V.Nagarajan
We have too Ethernet problems using LPC2368 and LPC2365 on Rev D and DP83848 PHY ; same connection from reference diagram of MCB2300 – 2007. Replacing the controller with Rev B all works OK.
But seems not the only problem: forums.nxp.com/viewtopic.php
Now, we shall to replace hundreds of “Rev D” devices around the world , and need to replace them with a “working ok release”. The LPC2368 errata –using a lot of words- says nothing about the change, and we consider than there is not enough information to estimate the impact and all code change needed for all routines or other drivers of peripherals.
Has somebody noticed (or have had other experiences) about the impact of this change using MDK and RL ?
Thanks in advance,
I have no idea about the real impact of this change. But the below thread may provide some hints.
http://www.keil.com/forum/17677/
====================> IB Shy, 7-Oct-2010 09:27 GMT Here's a classic example of what not to do:
/* Reset Reduced MII Logic. */ MAC_SUPP = SUPP_RES_RMII; for (tout = 100; tout; tout--); MAC_SUPP = 0;
It fails when full optimization (-O3) is selected.
And where does it come from? LPC32_EMAC.C And who supplies it? KEIL
Whoops. <====================
====================> Per Westermark, 7-Oct-2010 09:22 GMT Configure a timer, read out the timer value and poll it until x ms have passed. This is trivial, and will not be affected by changes of compiler optimizations, changes of flash caching etc. <====================
