Hi, have anyone managed to run (including debug etc.) uVision 4 on a virtual machine using windows 7 64bit (Windows 7 32bit VM). I can run it but I can't see the uLink. Thanks
hey matey.
i use vmware and done it with an xp virtual machine on a 64 bit win 7 host. worked well. also with ulink2.
i'm running uVision on a win7 x64 VMWARE machine. the hostsystem is a vista x64.
everything works fine. you have to install the ulink drivers on both of your systems: onyour host system and in your vmware machine
