file size in usb host
Hello Sir,
I am working on usb host using LPC2468 and i am using usb hostlite source code .I converted this source code compatible for FAT32 system.I am facing a problem when I create a file with extension RTF or DOC and try to write data less than 100kb and open this file on PC every thing is ok but when I write data greater than 100kb and try to open this file on PC there is a message on PC.
An unexpected error occurred while reading filename.
In USB hostlite WRITE_SIZE is given 10 * 1000000
what,s the reason for that?
Thanks & Regards
Rohit
  • I'm not sure, what is the direct cause of your troulbe.
    Get more clues on your problem.
    This error message suggests directory on the media is broken.
    Confirm it by reading out the directory sector from the media, using a disk utility on PC.
    Disk Probe
    - Included in Windows install CD/DVD, in \Support\Tools folder
    or
    - Windows XP Service Pack 2 Support Tools
    " href= "http://www.theabsolute.net/sware/dskinv.html">www.theabsolute.net/.../dskinv.html
    The structures of directory and its entries are described in
    MS FAT32 System spec
    msdn.microsoft.com/.../gg463080.aspx
    There are easier explanations on the web, for example,
    www.easeus.com/.../root-directory-management-in-FAT32.htm
    Interpret the sector read out, and specify broken field of directory entry.
    These functions touch to directory entry.
    usbhost_fat.c
    - FAT_CreateEntry() - make new entry
    - FAT_PutSFN() - Filename
    - FAT_UpdateEntry() - File length
    - FILE_Close() - File length
    Now that on debugger, you'll trace why one of these function puts wrong value to the directory entry.
    Tsuneo
  • Thanks Sir for your kind support
    Sir, I notice that when i use 100 in place of MAX_BUFFER_SIZE which is 4000 in usbhostlite source code problem occur.
    but if i use MAX_BUFFER_SIZE equal to 4000 then there is no problem.
    One thing more i want to confirm why WRITE_SIZE is (10 * 1000000)
    is there is any special reason for that?
    Thanks & Regards
    Rohit
