I am using the Keil SAM3U-EK with MDK 4.50 and Ulink Pro. The RTX HID example (Keil\ARM\Boards\Atmel\SAM3U-EK\RL\USB\Device\RTX\HID) from MDK 4.20 work perfectly but the RTX HID example from MDK 4.50/4.53 ends in an OS_ERR_FIFO_OVF error when I connect the USB. Does somebody use RTX and HID with the new libraries (4.50/4.53)? Or knows the reason for this fifo overflow? Is this a bug in the library/RTX?
Thanks in advance, Michael
I have the same problem on another target (STM32F103).
If I include the USB library and initialize it in my application, the application either reboots or end up in the os_error(OS_ERR_FIFO_OVF) function.
Did you find a explanation or solution to this problem?
