problem adding license
unable to get Keil registered stipuleted with cy8c001b kit. The license obtained thru internet on my e-mail id when added shows this error
klc.M0003: Unable to register your LIC number. Confirm if the number you entered is correct then try again. If the problem still exists, try to register directly from the Keil UV4 IDE "License Management" dialog.
Am doin exactly whats prescribed, copying and pasting license number as said.
Also a 30 days trial of Keil mentioned in PSoC Creator 2.0 software given with the CD is not working.Am losing work, kindly address this issue ASAP.
