How to make the arm linker decompress the second correctly with "RW data compression"?
title: How to make the arm linker decompress the second load region while both 1st and 2nd region are applied "RW data compression"?
I got a below scatter file (a simple version of my complex scatter file)
LOAD_REGION_01 0x0
   EXECUTION_REGION_01  0x0
      ABC.o (+RO,+RW)
LOAD_REGION_02 0x0
   EXECUTION_REGION_02  0x100
      DEF.o (+RO,+RW)
The RW data compression is applied automatically and I got a binary with size 0x40 (0x20 for LOAD_REGION_01 and 0x20 for LOAD_REGION_02 ), the got a link.info as following MAP file.
 Load Region LOAD_REGION_01 (Base: 0x0, Size: 0x30, Max: 0x000000a0, ABSOLUTE)
    Execution Region EXECUTION_REGION_01 (Base:0x0,Size:0x30,Max:0xffffffff,ABSOLUTE, COMPRESSED[0x20])
 Load Region LOAD_REGION_02 (Base: 0x30, Size: 0x30, Max: 0x000000a0, ABSOLUTE)
    Execution Region EXECUTION_REGION_02 (Base:0x0,Size:0x30,Max:0xffffffff,ABSOLUTE, COMPRESSED[0x20])
I found that the size of load region after compression is 0x20, but the start address of second load region is 0x30 ! And, the decompression of first region work correctly, but arm try to decompress the second region from address "0x30" not "0x20".
Therefore, a wrong decompression result is produced. How to make the arm linker decompress the second correctly? Or how can I assign the load address of second load region LOAD_REGION_02 with attribute +0 (since the size load region 1 may changed...) ?
I read all the user manual but no answer...
