Hello friends
Up till now i have used Keil compiler to write code for LPC2148
Now i want to write code in GCC compiler
I never tried GCC compiler to write code for LPC2148
Is there any source from where I can learn on my own.
What tool chain i require to compile code in GCC
I am not looking for complex code right now
Some simple code.. and step by step procedure to compile the code
I have lpc2148 kit to test the code
please help me!!!!!!
check if this page helps www.siwawi.arubi.uni-kl.de/.../
http://www.keil.com/appnotes/docs/apnt_199.asp
http://www.keil.com/download/docs/233.asp
www.lmgtfy.com
Note that you don't write a program in a compiler; You use an editor to write the source files of the program, and then feed those files to the Compiler to translate into Object form...
Thanks guys for the links
it helped me a lot
i got arm-tool chain now starting programs
thanks
