hi,
I am working with MCB2300 , which has LPC2378(ARM7 ,32bit) . I had written a code in which after performing a task the MCU goes into sleep mode. I have not given any interrupt sub routines. and no interrupts are enabled.
I am not able to program the MCU throug JTAG. Kiel error is as follows "No JTAG Device Found". I feel that the MCU is trapped in idle mode , hence the JTAG interface is also not active.
Please tell me if there is alternate way of programming the MCU , other tahn JTAG which would be active in the idle state , or suggest some method to get it out of the idel state.
int main() {
// perform task state1();
// goes to idle mode PCON |= 1 ;
state2();
return 0; }
What does the Datasheet say?
This is a device-specific question, so it would be more appropriately directed to the chip manufacturer (NXP, in this case) rather than a compiler vendor (Keil)...
Set P2.10 port to low on reset, the on-chip serial bootloader runs. ISP jumper (J10) on the MCB23xx board makes this pin controlled over COM0 serial port. FlashMagic is the utility for ISP over the serial port. http://www.flashmagictool.com/
Tsuneo
Ah, here is better description
MCB2300 User's Guide - Connecting with Serial ISP www.keil.com/.../mcb2300_su_connecting_serial.htm
Thank You very much.
Now well it seems that it was a stupid question. I had a misconception that MCU will respond to JTAG in the worst case.
