Re:AT89c51 connections are not working
Yes bro i got what was the problem, the problem was that i was trying to connect the leds with Anode with ground that's why they are blink so low.
what i did i connect the Anode to Micro-controller Pin and Cathode to +5 and now my led blink very bright.
try that its works fine.
  • Yes, the LED:s will light very weakly if you try to have the processor source current. The traditional 8051 is very, very, very much more capable sinking current.
    But an issue here - you don't mention anything about any serial resistor. A LED can basically consume an "infinite" amount of current, because the dynamic inner resistance is very low. So a LED is basically current-controlled. You adjust the light intensity by changing the amount of current and the voltage over the LED is almost constant.
    With 5V supply voltage and maybe 2V LED voltage - where do you "burn" the remaining 3V? Without a series resistor, the processor will fight all it can to sink all the current that the LED can conduct. You just have to have a series resistor to get somewhere to burn away the excess voltage or you will be pushing the processor pin way outside specifications (and get an equilibrium where either the LED fails, the processor pin fails, the power suppoly fails, or the processor pin do not manage to draw the signal lower than about 3V.
  • the datasheet clearly state how much current is available in source and sink mode.
    PS there is a trick here, if you, for debugging purposes, want to temporarily connect a LED between a pin and gnd. you can for plain vanilla derivatives omit the series resistor
  • Actually, the datasheets normally don't tell you how much current is available - what they tell you is the limits which your external circuitry must not exceed...
