Need help Minimon + C167 + 29F400 (Read Ok/Write impossible)
Need help for Minimon + C167 + 29F400 (Read Ok/Write impossible)
Hello all!
I try to write in 29F400 but I need help with Minimon.
I did a lot of tests for hours and hours.
I read lots of informations on the net.
Infineon C167CS User Manual is very useful but I need help.
I can read 29F400 with success OK!
But impossible to Write or Erase...
I had set driver A29F400b.hex
I think the problem come from the registers settings Buscon and Addrsel because maybe I don't understand all very well.
What should be the settings in the [Register] and [Memory] section in file Default.ini ?
What should be 29f400 start address with my config?
Here is my config:
C167CS-LM (No internal Rom)
8mhz x 3 = 24mhz
Connected in Boot-Mode with asc0 port (Usart, NOT K-line)
4MB Flash (AM29F400BB-55)
Word Mode (16 Bit ; Pin "BYTE" to +5V)
16 Bit demultiplexed Bus
OE to C167 Pin CS0 (P6.0)
WE to C167 Pin CS1 (P6.1)
CE to Ground
*Reset: BUSCON0=0680
*Reset: SYSCON=0400
*Reset Configuration: External Bus enabled
*Reset Configuration: 16 Bit demultiplexed Bus
*Reset Configuration: WR# and BHE# retain their normal function (P0H.0=0)
*Reset Configuration: On chip watchdog timer is disabled (RD#=0)
*Reset Configuration: Lengthened ALE signal
RP0H=00C7 (5 "chip select" activated) ...But I think only 3 CS signals are used, CS0,CS1, and CS3 connected on 74HCT574D Clock Input (Pin 11)
Address Pinout
29F400 / C167
A0 / A1
A1 / A2
A2 / A3
A3 / A4
A4 / A5
A5 / A6
A6 / A7
A7 / A8
A8 / A9
A9 / A10
A10 / A11
A11 / A12
A12 / A13
A13 / A14
A14 / A15
A15 / A16
A16 / A17
A17 / A18
Data Pinout
29F400 / C167
DQ0 / AD15
DQ1 / AD13
DQ2 / AD11
DQ3 / AD9
DQ4 / AD0
DQ5 / AD2
DQ6 / AD4
DQ7 / AD6
DQ8 / AD14
DQ9 / AD12
DQ10 / AD10
DQ11 / AD8
DQ12 / AD1
DQ13 / AD3
DQ14 / AD5
DQ15 / AD7
Thank you for your big help!
Chris
  • You are connecting signals:
    CE to Ground
    Shouldn't CE go to CS(0), OE go to RD, WE go to WR? Find an example schematic from Keil to see what I mean... Keil should have example startup code to go with it, so you can see how the BUSCON and other registers are set up to match the circuit design.
    Also, Flash won't erase or write unless you program the Flash Command Register properly. How are you using the Command Register?
    It is too bad you are using the C167CS-LM with no internal ROM but you need Flash so you're trying to use external Flash, from what I just read of MiniMon it has support for on-chip Flash programming, but not external Flash. Isn't your application better suited for a 'C166 variant with on-chip Flash? There's better tool support for on-chip Flash in my experience, especially for the newbie.
  • Hello!
    It's a Automotive ECU and I can't modify it.
    For the registers, I have disassembled original file an here is :
    008046: MOV CP,#F206h
    00804A: NOP
    00804C: MOV DPP0,#0024h
    008050: MOV DPP1,#0028h
    008054: MOV DPP2,#0025h
    008058: EXTR #1
    00805A: MOV XPERCON,#0C03h
    00805E: BFLDH SYSCON,#FFh,#E3h
    008062: BFLDL SYSCON,#FFh,#0Eh
    008066: MOV ADDRSEL1,#1008h
    00806A: MOV ADDRSEL2,#FFF0h
    00806E: MOV ADDRSEL3,#00A0h
    008072: MOV ADDRSEL4,#FFE0h
    008076: BFLDH BUSCON0,#DFh,#45h
    00807A: BFLDL BUSCON0,#FFh,#BFh
    00807E: BFLDH BUSCON1,#DFh,#85h
    008082: BFLDL BUSCON1,#FFh,#8Eh
    008086: BFLDH BUSCON2,#DFh,#05h
    00808A: BFLDL BUSCON2,#FFh,#2Eh
    00808E: BFLDH BUSCON3,#DFh,#85h
    008092: BFLDL BUSCON3,#FFh,#AFh
    008096: BFLDH BUSCON4,#DFh,#01h
    00809A: BFLDL BUSCON4,#FFh,#3Fh
    00809E: EXTR #1
    0080A0: MOV PICON,#00CFh
    0080A4: MOV STKOV,#F228h
    0080A8: MOV STKUN,#F2C4h
    0080AC: MOV SP,#F2C4h
    0080B0: MOV R8,#003Bh
    0080B4: MOV DPP3:3D06h,R8
    0080B8: EXTP #0002h,#1
    0080BC: MOV 2000h,R8
    0080C0: EINIT
    I have used this but I don't know if DPP0, DPP1, DPP2, DPP3, STKOV, STKUN, CP, SP are necessary :
    XPERCON : 0C03
    SYSCON : E30E
    ADDRSEL1 : 1008 (I have tried with 100A for 4Mb)
    ADDRSEL2 : FFF0
    ADDRSEL3 : 00A0
    ADDRSEL4 : FFE0
    BUSCON0 : 45BF
    BUSCON1 : 858E
    BUSCON2 : 052E
    BUSCON3 : 85AF
    BUSCON4 : 013F
    PICON : 00CF
  • Hello,
    I dont know if this thread is closed... but i know well this problem with automotive ECU (may be this is a Siemens unit?)
    You have to rewrite (and recompile) the minimon driver in order to correct the memory patterns:
    The problem is that the data lines are crossed (for routing simplification): when the C167 "wants" to write the "sequences" (see the amd datasheet)the memory doesen't see the right values.
    for example, in some cases you must write "44h" on the proc side if you want the memory to see part of the unlock sequence "A0h".
    But you surely already had the answer.
    Regards.
