When I set up a simple project for the LPC1759, access to one SSP0 Serial Port register generates an access violation (Error 65) at address 0x00000020, when the LPC_SSP0->ICR register is written. All the other registers appear to function. In the following code, when I run the simulator, the LPC_SSP0->CR1 register write works correctly, writing to address 0x40088004, but the following write to LPC_SSP0->ICR, address 0x40088020, generates the access write fault to memory address 0x00000020. The write to 0x40088020 works correctly, and the simulated peripheral behaves normally. I can map address 0x00000020-0x00000023 as read/write and supress the error, but is this a bug in the Keil peripheral simulation? Here is the entire code: The project is set up as an LPC1759.
#include <lpc17xx.h> int main(void) {
//This access works normally
LPC_SSP0->CR1 = 0;
//This generates Error 65
LPC_SSP0->ICR = 0;
return 0;
} void SystemInit(void){}
Is your peripheral powered up?
Both SSP0 and SSP1 peripherals are powered up. The port works normally if this address is set to R/W, but this address is not part of the SSP0 register set. The port woks in both the simulator and when the executable is run on the chip.
