SLIP problem
Im working with an MCBSTM32E (STM32F103ZE chip) evaluation board and Im trying to create a web server on my board. Because theres no Ethernet controller on board Im using an external WiFi module (RS9110-11-21 from Redpine Signals). Ive configured UART2 as my serial connection to the module.
In the Net_Config.c file ive unchecked the Ethernet Network Interface and have enabled the SLIP interface. When I try to compile the code I get the following build output message:
Build target 'STM32 Flash'
compiling Net_Config.c...
linking...
.\Obj\Test.axf: Error: L6218E: Undefined symbol dhcp_vcid (referred from at_dhcp.o).
.\Obj\Test.axf: Error: L6218E: Undefined symbol own_hw_adr (referred from at_dhcp.o).
Target not created
The serial driver file Serial_STM32x.c is included and modified.
Has anyone encountered the same problem?
BTW if I enable the Ethernet interface I dont get the error messages but the program will get stuck in the init_TcpNet() function. (Fatal Error Handler)
Thanks,
Chris
  • This is the output from the debugger (SLIP full debug, ICMP full debug):
    SLIP:Initialize SLIP interface
    SLIP:Dialing number:
    SLIP:Link up, SLIP Connected.
    SLIP:END char Received, Frame valid.
    ICMP:*** Processing ICMP frame ***
    ICMP: ECHO Request received
    ICMP: Identifier: 0x0300
    ICMP: Sequence: 0x0900
    ICMP:Sending ECHO Reply
    SLIP:Sending SLIP frame...
    SLIP:Transmitting queued frame.
    It seems like the uC is handling all the data appropriatly...
    Therefore the problem has to be on the WLAN module. Or could it be that the SLIP send function, to which I have no access to, is causing all the troubles?
    Therefore the problem has to be on the WLAN module. Or could it be that the SLIP send function, which is not accessible, is causing all the troubles?
  • After 4 weeks of trying, debuggin, hoping and sweating I was able to get my server running.
    The problem was in the SLIP_connect() function:
    This function provided by the TCPnet library sends "CLIENT<CR>" over the UART interface to the SLIP server (in my case the WLAN module).
    After examining all the serial data it seemed strange to me that all the AT commands were terminated by <CR><LF> except the CLIENT command. I just had to use com_putchar( <LF> ) after the SLIP_connect() function call.
    Id like to thank again for all the help I received.
  • Thanks for your posts here...
    They will surely help other..
    yateesh
  • The default Null_Modem.c driver is in the library. However you can copy the source code of this driver from .\ARM\RL\TCPnet\Drivers\Null_Modem.c to your project folder and add it to your project. Then modify it according your needs.
    When you build the project, this driver will replace the null modem functions from the library. This is a preferred way and much better than hacking the com_putchar() function.
  • Hi!
    I have the same dhcp_vcid problem
    linking...
    .\Obj\Http_demo.axf: Error: L6218E: Undefined symbol dhcp_vcid (referred from at_dhcp.o).
    Target not created
    I tried to disable the dhcp_disable () call in my source code then rebuild all target fills, it did not work. Any idea how to solve this problem?
  • Hi! Refering to this problem:
    linking...
    Target not created
    I just found out that I need to do the following two things to get it work:
    (1) #define DHCP_ENABLE 0
    (2) Do not call the dhcp_disable () function
    Is it means I can not enable the DHCP function?
