Hello All,
I am trying to use the GNU NANA in my project for Invariants and Quantifiers. I am facing some issues with macro expansion (the macros are already written by NANA people).
Whenever I use the MACRO (A, E, and C)in my code and compile it, I get an error as "error: #29: expected an expression". The way I am using it is as in following code snippet:
int main(void) { int q[5] = {1,2,3,4,5}; I(q[4] == 5); N(q[4] == 5); I(A(temp = 0, temp < 5, temp++, q[temp] <= 5)); return 0; }
I got above error for line "I(A(temp = 0, temp < 5, temp++, q[temp] <= 5));"
I have also seen the expanded macro in the preprocessed file and it look like this:
int main(void) { int q[5] = {1,2,3,4,5}; do { if((1)) { if(!(q[4] == 5)) { _I_default_handler("I(" "q[4] == 5" ")","test.c",8); } } } while(0); do { if((1)) { if(!((!(q[4] == 5)))) { _I_default_handler("N(" "q[4] == 5" ")","test.c",9); } } } while(0); do { if((1)) { if(!(({ int _A_result = 1; temp = 0; while(temp < 5) { if(!(q[temp] <= 5)) { _A_result = 0; break; } temp++; } _A_result; }))) { _I_default_handler("I(" "A(temp = 0, temp < 5, temp++, q[temp] <= 5)" ")","test.c",15); } } } while(0); return 0; }
There is some problem while returning _A_result. I tried compliling this with CodeSourcery, and it works fine with that.
Does keil not work well with macros?
Thanks in advance
Does your code expand similarly with the GNU toolchain?
do { if ((1)) { if (!(({ int _A_result = 1; temp = 0; while(temp < 5) { if(!(q[temp] <= 5)) { _A_result = 0; break; } temp++; } _A_result; }))) { _I_default_handler("I(" "A(temp = 0, temp < 5, temp++, q[temp] <= 5)" ")","test.c",15); } } } while(0);
The above expanded line have a full {} block with local variables inside the conditions of the if statement.
The block inside the if conditional looks like:
{ int _A_result = 1; temp = 0; while (temp < 5) { if (!(q[temp] <= 5)) { _A_result = 0; break; } temp++; } _A_result; }
Quite an interesting "expression" for the if statement to evaluate...
The GNU toolchain have a lot of extensions, so you have to verify what actual code that the GNU compiler would see. Besides the statement block as "expression", there is also a temp variable that is never declared anywhere.
Not sure how much documentation you read.
ftp.gnu.org/.../nana_2.html
Some important nuggets to consider: "Nana makes use of two GNU extensions in its library so you really should be using 'gcc'. Some of the code can be used with any C compiler, though it may not be worth the bother. The dependencies on gcc are in 'Q.h' which uses the statement value extension and in 'L.h' which uses the variable number of arguments extension to 'cpp'."
And under known problems: "The 'Q.h' macros depend on the statement value extension to GNU CC so if you wish to use them you must use GCC. This can be fixed for C++ in a possibly useful manner, I can't see any solution for C."
So maybe you should reconsider your question "Does Keil not work well with macros?"
Thanks for the replay, I have gone though the documentation. I take my words back. BTW, I wanted to use something like GNU NANA with the keil. If you know any pointers please point.
Thanks for your help.
